picking by global table in process flow
kleopatra_a
kleopatra_a
[ FlexSim 21.1.4 ]
Hello everyone! In the attached model i want the forklifts to pick a pallet from a rack based on a picking list. I have create a global table named "PickingList" and with process flow i tried to create the logic above but it doesn't seem to work. Any ideas?
Thank you in advance!Process flow 1 backtoback.fsm
mitregatomasz90
Hi
First in Pull from list block change pullitem to puller. You want to find item Where label Itemcode is equal to the label on token, and in SQL You need to change token into puller
Then in List block select the list that You want to pull from. Because now You have Internal List.
Best regards
kleopatra_a
Hey @Tomasz MG. Thanks a lot that works fine. My only problem is that i want the forklift to pick the entire pallet not only one sku. How am i going to achive that?
mitregatomasz90
Push pallet on list or in load block write token.pulled.up. First option will be better because now You have all boxes on list
ryan_c10
Hi @Kleopatra A,
Do you have any further questions here? If not, we will close this case in our tracker.
In addition, please ensure that you reply to answers using a comment rather than making a separate new answer. That helps to keep things better organized on this forum. See Best practices for using this Answers site - FlexSim Community for more info. Thanks!
kleopatra_a
No i do not have any further questions, thank you again for your help! 🙂
