Pick palet to taking product and place in same position
anutt_k
anutt_k
[ FlexSim 23.1.4 ]
Hello. I want to model Transporter to picking pallet and taking some of product and place pallet at same position.
I try to find slot position before picking. Then it should place after taking 3 product at stacking level 2 position.
I has attached model here. Thank You.
หยิบ Pallet ออกแล้ววางคืน_autosave.fsm
moehlmann_fe
Observer
Observer
What you need to do is store the pallets current slot on a label (or somewhere else). Then, after the item was loaded, assign it back to that same slot.
-pallet- -autosave_1.fsm
anutt_k
Greate. That it I want to do. I want to assign it back to that same slot. Thank You so much.
anutt_k
I suspect. Why in this logic it have Custom Code : Assign slot .
When bring it out from sub flow the model can still to work.
I don't understand a code inside Assign slot.
moehlmann_fe
Observer
Observer
Yes, in this case it also works without the activity, because the slot the pallet should return to and the first available slot in the storage are the same.
The "Assign slot" custom code activity makes sure that the pallet is placed in its previous slot again if this is not the case.
Another way to think about this: By default, the "Find Item" activity assigns the found slot to token.item. Instead of searching for a new slot, we assign the previous slot to the item again.
anutt_k
Thank You for explain.
