Performance Measure Exception
daniel_a5
Message 1 of 8
daniel_a5
[ FlexSim 18.0.10 ]
I believe the issue that appeared in this question:
https://answers.flexsim.com/questions/48375/performance-measure-exception.html
Seems to still be occuring in Flexsim 18.0.10. Installing the templates still seems to fix the issue.
performancemeasuresexception.fsm
Replies (7)
Message 2 of 8
JordanLJohnson
The attached model doesn't have any performance measures in it, and I didn't get any exceptions when I ran the model or the experiment. What are the exceptions you are seeing?
Jordan Johnson
Principal Software Engineer
Message 3 of 8
daniel_a5
@jordan.johnson
I've opened the model, opened the experimenter and then ran the experiment. Not much information in the exception I'm afraid!
Message 4 of 8
JordanLJohnson
That exception seems to indicate a problem with performance measures, but the model you have posted doesn't appear to have any:
Is that what you would expect? Also, does the problem occur in version 2019?
Jordan Johnson
Message 5 of 8
daniel_a5
19961-performancemeasuresexception2.pngYes that is what I expect, I haven't intended to have any performance measures.
This is the line that throws the exception if that helps. The "Average WIP" chart is populated in the ChartTemplates folder, which then is copied into the TempTemplateData node. Installing the chart removes this node which is why this exception is not seen after the chart is installed.
The issue isn't present in version 19.1.0
Message 6 of 8
benjamin_w2
Hi @Daniel A5, Is there anything else we can do to help you with this question?
Message 7 of 8
daniel_a5
Hi @Benjamin W2
We have resolved the issue by installing the templates, it was just to let you know that this appears to still be a problem in version 18.0.10
Message 8 of 8
benjamin_w2
Sounds good, thank you for letting us know!
