Percentage of queue items
daniel_c
daniel_c
[ FlexSim 18.2.2 ]
I'm trying to get a statistical distribution on mi queue. I have it set with a max capacity and I know which part and how many are in my queue at all times.
i.e. data that would help me see the percentage of how many times my queue had 4 or 10 parts (from 1 to 10).
Also if you consider a Statistics Collector please elaborate a bit since I haven't use that much.
ipk-part-count.fsm
joshua_s
This uses the stat collector and process flow. In process flow, a label "Count" is assigned a tracked variable. Then every time the content changes in the queue, The tracked variable is updated. Then in the stats collector, it adds rows 1-10 then in the stats collector it tells it to read the total time it is at each of those specific values (1-10). @jordan.johnson helped me with a lot of the stats collector part if you are looking for more resources into how to use the stats collector.
stats-collector.fsm
