Patch to resize a Pallet after separator
julio_r
julio_r
[ FlexSim 24.1.0 ]
the last few versions introduced a feature where the pallet frame was adjusted when you put things on it.
This was very helpful so it looks good when stacking full pallets but now when you tke things from the pallet the frame stays bigger than it used to, so when you stack empty pallets again they seem to float in the air.
I have made a simple model with a correction in the exit trigger of the separator, but this would be better if it was inside the pallet trigger or somewhere where its done automatically.
Patch to resize a pallet after separator.fsm
FelixMoehlmann
This was previously asked and @Jason Lightfoot's answer seems to indicate that the developers are aware of the issue.
https://answers.flexsim.com/questions/143470/pallet-stacking-packing-method-misbehaves-when-reu.html
The post also a link to a library by Jason that contains a pallet version that adjust the size when an item exits as well.
https://answers.flexsim.com/questions/129843/problem-stacking-pallets-in-rack.html#answer-container-...
See the "OnSend" eventfunction in the "palletspaceexample" model.
Jeanette_Fullmer
Hi @Julio R, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
