Parametrize things which may also influence other layout or objects
z8c9526489
z8c9526489
[ FlexSim 21.2.1 ]
We have to simulate a warehouse which uses AS/RS and AGV. AGV is used to deliver pallet to crane in dock area. When AGV arriving the certain location, the AGV puts the item down and the crane will take the item away. we have 2 types of slots in AS/RS. Different types of slots have its own dock area layout(The route of AGV differs also).
My question is: How to parameterize the ratio of multi types of slots under condition that the parametric change transforms other objects(including the dock area layout and AGV route) also? Is it possible to make the addition parametric change done automatically(Maybe by Script or process flow or others)?
joerg_vogel_HsH
Theoretically, yes it is possible, but we need more information how a change occurs! You can build your model twice and switch from one Lay-out to a second. And/Or you can set different virtual distances in one layout. You can change locations. If you want to run multiple instances in an experiment you need to control your variables through tool box parameters.
ryan_c10
Hi @Z8c9526489,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
