Parameters cannot be linked with GlobalTable
ting_wei_h
ting_wei_h
[ FlexSim 23.0.0 ]
In my current understanding, we can use On Observation in Reinforcement Learning Tools to allow my Agent to observe the current system status.
The official example is as follows:
I now want to observe the values in the GlobalTable through On Observation as the States for my current reinforcement learning, but I don’t know why my code cannot make the values of Parameters change together with the values in my GlobalTable. I want to know how to use FlexSim Does China allow such an operation?
Here is my example:1708757108222.png
FlexSim Problem2024224.fsm
moehlmann_fe
Your code is correct but you have not defined any decision events, so the On Observation code is never run.
Also, you do not have to use the On Observation trigger for this. You could change the parameter at the same time as the table entry.
