Pallet on the wrong place
christoph_gruberYEAZC
[ FlexSim 19.2.4 ]
Hi @Joshua S I tried to replicate your solution for the problem that my AGV travel backwards (without lift). So I take a Transporter instead of a TaskExecuter and I edit the z-axe in the properties gerneral tap "Visual/Animatios". Than my AGV travel backwards but after he takes a pallet the pallet is infront of the AGV (Transporter) , see my picture also. What changes had you made too in you model, see
https://answers.flexsim.com/questions/75968/agv-feature-forklift-using-agv-module.html
23990-agv-handover-conveyor-2.fsm
that the box is on the right place at the lift?
joshua_s
Can you share the model that the picture is from?
You can use a Change Visual activity to offset the pallets location after it's been loaded.
Thank you very much for your quick responde @Joshua S
I put all Transporter in a Group and with a Wait for activity (...Loaded Item) and a Change Visual activity it works.
Best regards
Chris
