Pack seven same items on conveyor into one
leekuanhung
leekuanhung
[ FlexSim 24.2.1 ]
Please see the attached model. dzfbsdf.fsm
The layout is as below.
The model will send a bunch of long rectangles, the rightmost station will color code them from Type 1 to 7, the centre station will join the 7 items into 1 solid item before sending out to the leftmost station and sink.
The joining I intended is to have the Type 1 reach Centre first, becoming the pallet of sorts. Then rightmost station to release 2 to 7 one by one.
moehlmann_fe
Observer
Observer
You don't need the list. Through the arrival trigger you already have a reference to the next item. You need to store a pointer to the first item though, so the next six tokens can know where to move the item.
Apart from that it's important to wait until items 2-6 have 'continued' on from the station so the restricted area is released. And for this to be possible only the first item should acquire the area between station 2 and 3. Otherwise items 2-6 would be prevented from continuing past station 2.
dzfbsdf_1.fsm
leekuanhung
Hi Felix,
I had placed your above model into Flexsim 23.0.4 instead and now at the leftmost station will display this message whenever the combined object go past.
FlexScript exception: Invalid down cast. Object is not an instance of the target type. at MODEL:/Station3>variables/onContinue
please see attached model. sdvdzsvsdf.fsm
Also, I had changed the centre station's On Continue to On Arrival to have it moving, why can't On Continue work like it did in 24.2?
moehlmann_fe
Observer
Observer
You didn't add the condition to the Acquire Area option on the middle station that makes only type-1-items acquire the next area.
That is both why OnContinue doesn't work (the items can't continue because the area is not available) and why you get an error when the batch arrives at the next station. The next request for the area is by the type-2-item. In the trigger code this item gets cast as a Conveyor.Item class variable. But because the item is not on the conveyor anymore, this is invalid.
