OptQuest permutation problem
dawid_dabal
dawid_dabal
[ FlexSim 17.1.2 ]
permutation.fsmI have a problem with permutation using OptQuest - I suspect that Lower/Upper bounds don't work properly.
In this sample model I want to find permutation:
Each variable is a cell in GlobalTable1. My PFM is GlobalTable1.cell(1,1).value and I want to minimize this value (my PFM is the same as Variable 1).
Solutions generated by OptQuest are between 1 and 7 - but they should be between 2 and 8 (lower bound = 2, upper bound = 8)
Is this a bug?
sam_stubbsYXX86
@jordan.johnson
Are you familiar with this issue?
JordanLJohnson
The lower and upper bounds for permutation variables are ignored by the Optimizer. As a workaround, you will need to write code that shifts the value in the table by 1:
var myValue = Table("GlobalTable1")[1][1] + 1;
This behavior is why the UI sets those values to N/A (or not applicable) when you change the variable type to permutation.
Jordan Johnson
Principal Software Engineer
