Optquest maximum number of variables?
stefan_haeussler
1 View
stefan_haeussler
[ FlexSim 16.0.7 ]
Hi all,
I have just set up a new project with Flexsim 16.0.4 where my initial plan was to optimize 10440 variables by using Optquest.
I defined the variables by using the script window which just worked fine, but when i looked at the .csv export at the end of an optimization run I realized that Optquest did only keep within the lower and upper bound for 8189 variables.
Is this the max. number of variables Optquest can handle?
I tested a scaled down model with 8172 variables and everything works fine.
Best regards,
Steve
JordanLJohnson
There is not a limit on the number of variables, as far as I know. However, the total number of iterations OptQuest will try is currently limited to 10000. You might run in to that wall quickly, with so many variables.
Jordan Johnson
Principal Software Engineer
