Optimizer run status stuck
rajankur6494
Message 1 of 9
rajankur6494
[ FlexSim 23.1.3 ]
Hi Team,
I am running 5 experiments using optimizer for 50 days of run time. Out of that 2 got completed and remaining stuck from 1 day as below:
What should I understand?
Is that due to the bug in model or something else?
Thank you!
Replies (8)
Message 2 of 9
joerg_vogel_HsH
This picture tells us, that two experiments have started, none finished yet and one has not started. Typically your model should be able to run without Experimenter or Optimizer being active about your run time without any errors several times. Then you can use experimenter and optimizer. Please watch system usage.
Message 3 of 9
Jeanette_Fullmer
Hello @Ankur A3, This issue was fixed in both the 23.2.1 and 23.0.11 and later. I see that you are using 23.1. You will need to upgrade your version.
Message 4 of 9
jason_lightfoot_adsk
Hi @Ankur A3, was Jeanette F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
Message 5 of 9
rajankur6494
Hi @Jeanette F,
Can you elaborate about the issue which is fixed?
Thank you!
Message 6 of 9
The first item in the list.
Message 7 of 9
rajankur6494
Hi @Jason Lightfoot,
What do you mean by list here?
Thank you!
Message 8 of 9
The list was a link to the changes listed in the release notes for 23.0.11:
"FlexSim 23.0.11 (September 8, 2023)
  • Fixed Experiment replications sometimes not finishing."
Message 9 of 9
rajankur6494
Ok @Jason Lightfoot
Thank you!
