Operator picking items from moving conveyor
charuhas_p
charuhas_p
[ FlexSim 21.1.2 ]
Hi -
Is there a way the operator can pick the items at an "unloading point" on a conveyor and stage it in a queue. Missed items will recirc back to the unloading point.
I would appreciate any help with this.
Thank You.
CP.
item intercept.fsm
jason_lightfoot_adsk
Yes you need to uncheck "Stop at end" in the exit Transfer's quick properties shown here
39483-1620953468514.pngAnd before that you need to send the items to the exit Transfer - eg from a decision point. Example attached.
item-intercept_jl.fsm
jorge_g39
Hi Jason,
What can I do if my operator just pick some items as in the example, but I want that the operator pick all the items (In the order that they arrive), not skippingQuestion.fsm anything.
moehlmann_fe
You have to check 'Stop an End'. Otherwise items that move past the exit transfer will not be picked up anymore.
Using a dispatcher should work as it does normally. Maybe check if all connections are correct and the 'Use Transport' option is set correctly.
question(2).fsm
jorge_g39
Thanks ! I also increase the size of the exit Transfer and that helps.
