Operator move follow the path
linh_thi_nn
linh_thi_nn
[ FlexSim 19.0.0 ]
Hi guys. Is there any way to create a path that operators can move based on those paths? I'm trying to create a path that operator can move and not go through the objects. I searched on the forum but didn't see it. Can you help me, please?
joerg_vogel_HsH
Network Nodes are objects for this. You connect each node with an object connection (”a” key connections). The path is by default bi-directional. If you need only one way, then you delete the connection between both nodes (“q” key). You bind an operator and any involved object ( queue, processor,..) by an object connection to the network to a node. You can set options how the operator behaves to do offset travels, this means he leaves the network and travels directly to an item.
Manual: Working with travel networks
linh_thi_nn
Thank you so much. I did it well. ❤️
chanykE2WUT
@Linh Thị NN Please provide your model in the latest version of FlexSim to get support from this forum in the future.
David
joerg_vogel_HsH
bump!
