Operator and Network Node
mdemalia
mdemalia
[ FlexSim 21.2.2 ]
Attached is an operator on a network that performs a travel, load and unload task. I want the operator to get to the network node and then perform the load/unload operation at the node. When I use the travel offsets for load/unload tasks the operator leaves the node and then does the operation. When I select use navigator or do not use offsets the operator stays on the node but there is no physical pickup of the boxes.
Essentially what I want to see is how an operator standing at a fixed point can transfer objects from one conveyor to a second. Without a network node the operator just enters into the conveyor and the visualization looks bad. Any help is appreciated on how to do this with the model.
Network Node Question.fsm
jason_lightfoot_adsk
You could add two more nodes at the positions you want:
Model attached.
network-node-question_jl.fsm
mdemalia
@Jason Lightfoot Thanks for this. Is there a general rule for how close a network node needs to be to an object being loaded to make the load and unload work properly? It appears as though there is a proximity between the operator and the load and unload task that the network node needs to be placed in order for this to work.
It was working before, it's just that we now have a delay with the operator loaded while it travels between the conveyors. There's no proximity switch as you'll see if you move the conveyors away from the network nodes.
