Opening customized dialog window instead of property window
sakamoto_ryosuke
sakamoto_ryosuke
[ FlexSim 20.2.2 ]
Hello, is it possible to open customized dialog window upon double clicking the 3D objects? Currently, when you double click the objects, property window pops up. But we want to change this if possible. If it needs to be created with SDK, that's also fine.
mischa_spelt
When you double click an object, the GUI that opens is the view that is referenced in the subnode >special/guifocusclass of the object's tree.
You can create your own view, for example in VIEW:/modules/YourModule, and update the guifocusclass accordingly.
sakamoto_ryosuke
@Mischa Spelt, Thank you for your reply. Is it possible to specify custom GUI created in ToolBox? I try to find the custom GUI (GUI 1 in this case) created it in the tree, but I couldn't...
Ben_WilsonADSK
@Ryosuke S,
If you're using the GUI builder, you can use the option "Redirect selected objects to this GUI":
Just make sure that whatever objects you want to use your custom GUI are highlighted RED, then choose that option.
sakamoto_ryosuke
@Ben Wilson Thank you for your reply. It's perfect.
