Open/Close output of a separator by condition
Telmo_Silva
Telmo_Silva
[ FlexSim 22.2.0 ]
Cenário 3.fsmHi there,
I am trying to block a separator using close and open the output of it. The condition is that the queue which is receiving the output of this separator has a length less then 60. I.e., when the number of elements in the queue is 60 the separator should have a closed output and when the queue has less then 30 elements it should open the output again.
However, what I am seeing is that, the output is not opening even though there is less then 30 elements in the queue. What am I doing wrong?
Jeanette_Fullmer
Hi @Telmo_Silva,
To receive a more accurate solution, please post your model or a sample model that demonstrates your question. It would be helpful to know what trigger these actions are attached to.
Proprietary models can be posted as a private question visible only to FlexSim U.S. support staff. You can also contact your local FlexSim distributor for phone or email help.
Telmo_Silva
Sorry about that. Completely forgot. Thank you
julie_weller
Hi @Telmo_Silva!
It's a lot easier to do that logic directly from queue PJ2 using triggers like you did. For example I added an on entry and on exit trigger to close and open ports and my logic for them looks like this:
I'm attaching the model here for reference:
cenario-3_1.fsm
Let us know if that helps!
carter-walch
You can also perform the same logic in process flow, but it is easier to do in the 3D model like @Julie Weller did. The following process flow closes the input port when arriving at content 60 in the queue, and reopens it when content arrives at 30
cenario-3.fsm
Telmo_Silva
Perfect. It works as I asked for. Thank you so much for your help.
