OPC UA instance specifier to access single value of array
mail7WJMZ
Message 1 of 15
mail7WJMZ
[ FlexSim 22.2.4 ]
I would like to re-open this topic: Using OPC UA to connect Fanuc robot - FlexSim Community
In conclusion, build-in Emulation GUI tool doesn't support specifying array index, we need to use internal Emulation in Process Flow.
So we can set node id to following format, where the %s is array index.
ns=2;s=Model;DiscreteInput[%s]
But it fails to read correct value of array, which is always zero.
I use OPC UA ANSI C Demo Server (Windows) as OPC UA server for testing.
UaExpert to modify node value, I set all boolean values to true.
Could you find out what is wrong in my model?
opcua_instance_v22.2.fsm
Replies (14)
Message 2 of 15
Jeanette_Fullmer
@Luciano Cavallero, @Tancredi Canonico, @Fiorenzo A, can you please take a look at this emulation-related question?
Message 3 of 15
lcavallero
Some OPC UA Server doesn't support direct access to a single element of an array ( the 'index range' functionality is not supported): please check if your server support this feature.
To avoid problem, if possible, transform your array of boolean into a set of single bool variables.
NOTE: the UaExpert client read and write all the array elements at once.
Message 4 of 15
jason_lightfootVL7B4
Hi @Steven Chen,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker.
Message 5 of 15
mail7WJMZ
I believe there is nothing to do at server side, because I am able to use Python to specify array index. I use UserCommand to run this Python code.
from opcua import Client
def read(url, node_id, array_index):
    client = Client(url)
    client.connect()
    value = client.get_node(node_id).get_value()[int(array_index)]
    return value
My goal is to do the same thing with emulation tool or internal emulation in process flow.
Message 6 of 15
That expression seems to be reading the whole array from the server and not the element which would be the part of the node_id expression (in FlexSim including the %s parameter).
Message 7 of 15
Jeanette_Fullmer
Hi @Steven Chen,
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question.
Message 8 of 15
mail7WJMZ
You are right that we can't use node_id expression to get only one element. So this expression is not valid.
Because FlexSim can't read array from OPC UA server (value is zero instead of an array), so it seems no any possible solution by using build-in funtionality in FlexSim.
The only solution is using Python or C++ external code to achieve this.
Message 9 of 15
It's not going to recognise the %s in Python - you'd need to test if you can read a single value from the array into Python using something like this for the nodeid:
ns=2;s=Model;DiscreteInput[5]
Message 10 of 15
mail7WJMZ
I tried but it's not valid expression for OPC UA node id.
Message 11 of 15
Doesn't that then suggest that the server is not configured to serve individual array values as Luciano suggested might be the case?
Message 12 of 15
mail7WJMZ
I afraid it's not expected to modify server. I hope at least FlexSim can retrieve the whole array from OPC server, but currently the retrieved value is zero with FlexSim. Could you add this to dev list?
Message 13 of 15
mail7WJMZ
@Luciano Cavallero, could you help adding this to dev list? To enable OPC UA to retrieve whole array from server.
Message 14 of 15
lcavallero
@Steven Chen : alredy in the dev list.
Message 15 of 15
mail7WJMZ
Thank you.
