OnMessage in wait for event
shanice_c
shanice_c
[ FlexSim 21.2.0 ]
Hello everyone, I have two process flows. I'd like to release token waiting in flowA by sending message from flowB. The token in flowA is kept in a wait for event activity and listen to onMessage.
It seems the token is releases but my model has exceptions below. How could I fix it in wait for event activity?1643545501811.png
testonMessage (1).fsm
jason_lightfootVL7B4
The problem is not in the WaitforEvent activity, it's in the ill-defined Assign And Send Message.
Your 'toObject' is NULL since it's the second, optional parameter that requires the activity name - not the first. The instance to use in gettoken() would not be "current", and also the token is likely unable to handle the message anyway.
Synchronisation like this is better done using lists - I recommend you try that.
ryan_c10
Hi @fiona.c, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
