One output value for 2 sinks in a dashboard
victor_alejandro_ht
victor_alejandro_ht
[ FlexSim 18.2.0 ]
Hi all,
I want one single satistic for the sume of the input of 2 sinks. Every time there is an entry in sink1 the input value must be multiply by 2 and for the sink2 the input value must be multiply by 4 and I want the final sum of those inputs. I have tried with a modification of the statistic collector value with no sucess.
I attached the model.
suma-sinks.fsm
regan_blackett
Is there A reason the Composite Throughput chart templates are insufficient?
Choose one of these and add the two sinks to the 'Objects' field and I think you'll get what you are looking for.
JordanLJohnson
Here is an updated version of your model:
suma-sinks-updated.fsm
I added a label to both Sinks called Multiplier. I removed the Total collector, and replaced it with a collector called BothSinks. That collector shows the input of the sinks, as well as the adjusted input of the sinks, which takes the multiplier in to account. Finally, I added a Calculated Table that sums the adjusted input of both sinks.
Jordan Johnson
Principal Software Engineer
victor_alejandro_ht
Hi Regan,
There is a reason composite charts are insufficient, because I need to multiply by a specific factor every time an item reaches a Sink. In other words the increment is not equal to the item input.
Perhaps I did not explain my self properly. Thanks for your reply.
victor_alejandro_ht
Hi @jordan.johnson
Thanks for your answer this is exactly what I was looking for. I have never used a Calculated Table before. I wil check it out.
