omniverse didnt run and cant add agv path in usd stage
a9080109
Observer Observer
a9080109
Observer
Observer
[ FlexSim 25.0.0 ]
I have made a version following the video's narration, but I found that sometimes it is successfully synchronized in the Live function and sometimes it is not. In addition, I would like to ask if the agv path can be added to the usd for modeling? I cannot add it smoothly. In addition, if I need to display agv-related functions on the usd, how can I do it?
kavika_faleumu
Hey @mark zhen, do you have specific times when it is successful or fails? It's a little hard to debug what's happening when it is inconsistent.
Yes, you can add AGV Paths to the model and save them to the USD Stage. Make sure you're not in a live session when adding stuff to the model. You can display whatever you want in the USD Stage -- it should be exported correctly from FlexSim into USD and then displayed in your USD viewer.
a9080109
Observer
Observer
I use explore open the usd file and click the flash to join then open the Flexsim click join !
a9080109
Observer
Observer
But when I start to push the path inside stage they have some bug will happen
kavika_faleumu
I just tested adding AGV paths to a USD Stage and exporting to USD. It seems to be exporting incorrectly. I'm not sure why that has changed. I will add it to the dev list and look into it.
a9080109
Observer
Observer
@Kavika F sir! so i have another method to do this?
kavika_faleumu
You can export AGV lines using the Omniverse Connector. I'm not sure how they'll behave when connected to a live session though.
