Object returns to origin when quick properties is on , no valid stats
mol_t
mol_t
[ FlexSim 19.0.0 ]
1. I noticed when the Quick properties tab is on and I try to select an object, it moves to the origin point. How can I disable this ?
2. When I try to pin to dashboard the objects queued, it says "No Valid Stats" even when the dashboard is open. What might be the problem ?no-valid-stats.png
* I am using Flexsim 2019 and a total newbie.
support5CRPZ
@Mol T Your setting looks like to have some problems in your model. The model should be uploaded in this question. And I recemmend to use the latestes edition of 2022 update 1.
mol_t
Thanks. It seems there was a problem with my computer, I reloaded it and it works just fine.
