Object Process Flow for Conveyor Can't be Saved as User Library
arunTTT2P
arunTTT2P
[ FlexSim 23.2.1 ]
Object process flow for a conveyor is not getting saved as a user library.
convlib.fsl
Arun KR
jason_lightfootVL7B4
I'm assuming you mean from right clicking the conveyor and adding that - the object flow of which it was a member should get added automatically, right? You can right click the process flow background and add it to the user library seperately, but then you need to add the user library instance to that manually.
Thanks for pointing this out - I'll send it to the developer team.
arunTTT2P
Yes it should be added automatically and it's not happening.
arunTTT2P
Can this be fixed in the next bugfix release?
Matthew_Gillespie
@Arun Kr This issue is fixed in 23.0.13 and 23.2.3 released today.
Matthew Gillespie
FlexSim Software Developer
