Object and entity size
HKSim
HKSim
[ FlexSim 24.1.0 ]
We have issues with object sizes. It seems like the CAD file we imported has a much larger scale than objects, so when adding objects (like beds) to the map we need to increase sizes a lot to make them visible. The problem is when adding patients. We tried to increase the size of entities (patients in our model) when they are created but it doesn't work and patients aren't visible in our model at all.
How can we make the entity (patient) size similar to other objects?
moehlmann_fe
It would be better to scale the CAD layout down, rather increase the size of objects. Otherwise you'd also need to increase the speed of all travellers to get realistic travel times and the traveled distance (if measured) would be wrong as well.
Jeanette_Fullmer
Hi @HK, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
HKSim
Thank you so much. This resolves the issue.
