Not able to delete label with no name
patrick_zweekhorst
patrick_zweekhorst
[ FlexSim 18.0.1 ]
When I have a label on an object that I want to remove it in the quick properties window is not possible if the label has no name. If you (by accident) first remove the name of a label in the quick properties window and after this want to remove the label this does not work. When you press the red X, the label (with no name) stays at the object.
Is this already a known issue?
You can of course work around this problem by giving the label a name again.
Thanks for fixing this problem
Patrick
matt_long
We'll add this to the dev list, thanks.
