Not able to connect controlpoint to queue
patrick_zweekhorst
patrick_zweekhorst
[ FlexSim 16.2.0 ]
I am making a model in which I use the AGV module. I use a script to make a queue and a controlpoint in a container. After this is done I want to A connect the controlpoint to the queue, but this is not working. Is this a bug or is this intentionally done? I have attached an example model ( connectionbug.fsm ) where I want to connect Queue112 to ControlPoint213, but this is not working. The code that I used to make the objects is in the script window.
Thanks in advance
arunTTT2P
Dear Patrick,
I didn't understand, why the connection is not happening.
Instead of createcopy(), when I used createinstance() it's connecting. Someone from FlexSim can give a better answer to this behaviour.
treenode container1	= node("BasicFR1", model());
treenode container2 = node("BasicFR1/BasicFR2", model());
treenode container3	= node("BasicFR1/BasicFR2/BasicFR3", model());
treenode bufferObject 		= node("Queue15", model());
treenode controlpointObject = node("ControlPoint2", model());
treenode buffer = createinstance(bufferObject,container3);
setloc( buffer, 2, 2, 0 );
treenode controlPoint = createinstance(controlpointObject,container3);
setloc( controlPoint, 3, 3, 0 );
contextdragconnection( buffer, controlPoint, "A" );
Regards
Arun KR
patrick_zweekhorst
Dear Arun,
Thanks for your quick answer. I will use the createinstance instead of createcopy.
Patrick
