Not able to change wait for event option
patrick_zweekhorst
patrick_zweekhorst
[ FlexSim 17.0.3 ]
I want to use a wait for an event ( the content of a queue needs to reach 0 ), but there seems to be a bug in the change rule in the OnContentChange event. No matter which change rule I select, after clicking somewhere else ( to close the pop up) and reopening the pop up the change rule is always "Change", and not the option I selected. This happens in 17.0.3 and in the 17.1 Beta version I tested.
Is this a known bug?
Thanks in advance,
Patrick
Matthew_Gillespie
Yes, this is a known bug that has been fixed for 17.0.4 that should be out soon.
This post shows a workaround using the tree to set the value.
Matthew Gillespie
FlexSim Software Developer
patrick_zweekhorst
@Matthew Gillespie Thanks for your quick answer, i tried to search the forum to see if it was there already but I got an error.
Edit: found it!
