Node.js for Running FlexSim Web Server Successfully
sakamoto_koUFFFM
sakamoto_koUFFFM
Hi.
During the installation of FlexSim Web Server ver24.2, the Node.js installation did not function.
I recall that with ver22.2, installing the Web Server on a PC without Node.js installed automatically opened the Node.js installation screen.
I tested this on multiple PCs, and the same behavior occurred on all of them. Is this the intended behavior for ver24.2, or is it an environment-dependent issue?
Furthermore, based on the above behavior, I determined that Node.js must be installed manually on these PCs. Which version should I use?
Version 20.19.6 worked correctly in my environment, but please advise if another version is recommended. As a precaution, I also tried the latest LTS version, v24.12.0, but buttons and other elements did not display correctly.
Thank you for your response.
Jeanette_Fullmer
Hello @sakamoto_koUFFFM ,
The developers have been notified of the issue where node.js is not installing with the webserver installer.
You can install node.js by running the following in power shell:
sakamoto_koUFFFM
@Jeanette_Fullmer
Thank you for your reply!
I understood that Node.js version 20 is required for FlexSim Web Server ver24.2 to function properly.
