Network nodes flexscript
10Dulkar
10Dulkar
[ FlexSim 22.1.4 ]
hello.
i have more than 2000 network nodes and I created, connected and made them one way using program. however I have to now change speed, spacing and connection type ( non-passing) using a program but I am unable to find the command for it. Can anyone please help how to get this done using script?
@Matthew Gillespie @Logan Gold @Joerg Vogel
Matthew_Gillespie
Those three settings are subnodes of the connection between two nodes. Here's an example of setting those three settings for all the out connections of a single network node:
treenode netNode = Model.find("NN1");
var connects = connectionsout(netNode).subnodes;
for (int i = 1; i <= connects.length; i++) {
    treenode connection = connects;
    connection.find("maxSpeed").value = 1;
    connection.find("spacing").value = 1;
    connection.find("connectionType").value = 3;
Matthew Gillespie
FlexSim Software Developer
10Dulkar
thank you Matthew. this helps.
joerg_vogel_HsH
You need to check which edge you want to change values for. If you do this on all network nodes and at each edge you will deactivate you network at all.
jason_lightfoot_adsk
To make the connection type easier to read you can use EDGE_NONPASSING instead of '3' and to make it one way use EDGE_NOCONNECTION. To restore passing use EDGE_PASSING
