Network node, task executers and process flow
mayuresh_j1
mayuresh_j1
[ FlexSim (other) ]
I am using process flow to control an operator (operator2) that transport material from one queue to the other. I used network nodes to control the path of movement of the operator, somehow operator2 is not following the network path. What will be the solution for it?
Thank You.
network-node-problem.fsm
Version: Flexsim 17.1.4
SCHamoen
@Mayuresh J The important thing you have to do is use a travel task to do the travelling. The load unload task only do offset travelling (read through the manual to find more info about offset travelling) So I changed the load unload by a moveobject and used travel task to do the movement.
network-node-problem-solution.fsm
Here is another post on this forum about the same problem: network node with process flow.
mayuresh_j1
@steven.hamoen
Thank You
