[ FlexSim 21.2.2 ]
I am currently experimentating with node based networks with nescessary offset travelling.
In the attached model below i need the task executor to be able to do both tasks on the same network:
I tryed to use the "D" connection, which works quite well for offset travelling and rejoining on another point, but if there is no "A" connection between nodes task executor will not travel directly.
And if I use both connections between those two nodes travel pattern looks like that, which is also not good for me:
So my question is:
How to connect the nodes and setup rest of model to allow both of those movements on one network node?
Thank you so much and have a nice day all!
Z.K.
