network license in computer lab - licensed for multiple users
mark_foiles
mark_foiles
We have a computer lab with FlexSim that checks out licenses through an on campus license server.
I would like to setup the computers to look for the license on our server, no matter who logs on. Currently I have to use the license activation window and enter the license server address each individual Microsoft Windows user or profile.
Is there a way to license the PC itself, so that any user who logs in will be able to open a licensed instance of FlexSim? Without reentering the license server information for each user?
Ben_WilsonADSK
UPDATE: this issue is now covered in the License Server Tools, which includes the License Server Installation Instructions.
In section 8. Activate client PCs there are two subsections, one of which is for multi-user PCs which will handle this situation.
Original response below:
Attached is a license file (flexsim_server.lic). Edit this file by changing "this_host" on line 1 to the IP address or name of the license server.
Then put a copy of this file on the client PCs, in FlexSim's program directory:
C:\Program Files\FlexSim16\program
Of course replace FlexSim16 with whatever version of FlexSim is in your Program Files directory.
This should tell the FlexSim installation, on a per-computer basis rather than per-user, where to look to get a license.
If you are using ports other than the defaults, you can specify your custom ports by following the example in the flexsim_server.custom_ports.lic file. Please see Flexnet's License Administration Guide, page 28 for more information about license file usage and syntax.
clair_augsburgerZGWRZ
Thank you very much Ben. Does this method also work with a FlexSim Healthcare network license ?
philboboADSK
Yes, this method works with HC, too.
Phil BoBo
Sr. Manager, Software Development
