Need help with batches
ernesto_daniel_ag
ernesto_daniel_ag
[ FlexSim 18.2.0 ]
Hi... I have a problem with the batch process, How can I make a "processor" process lots of pieces, that the operator moves those pieces in the same amount and that in both cases the operator waits to reach that amount to move them.
joshua_s
Here's a model with 2 different scenarios, didn't know which one exactly you were going for. The key is to set the max capacity of the operator to the batch size. If you are using a queue after your processor, you can set it to perform batching and set the batch size.batching.fsm
