Need help using label values in a statistical Collector
tee_hiett
Message 1 of 10
tee_hiett
[ FlexSim 20.1.3 ]
In the attached model of Corona's vaccination process, each patient must be observed for 15 minutes before leaving after the vaccination. To achieve this a patient enters the auditorium from the rear and goes to the leftmost available seat in the first row, the next patient goes to the next available seat, etc. The same process is followed for subsequent rows. When the first arrival on row one has been there for 15 minutes, he or she will depart through the exit on the upper left. When all the patients in a row have left, the next patient entering will go to the first available seat on that row and the process will continue for that row with subsequent patients feeling that row
With help from @Matthew Gillespie, I have developed the process whereby each patient has a label with the name "Used" which is set to 1 (Activity "Mark Seats Used") when acquired by a patient. When all the patient have left on a row, the value of "Used" will be set to 0 (custom code in Activity "Clear Row").
I can build a census chart of the patients in the auditorium but I would like to build a census chart of the seats which are unavailable (have the label "Used" with the value of one).
I have searched the help documentation and the answers.FlexSim site for any idea of how to do this but have not found any ideas
Any suggestions would be appreciated.
TeeCovid19 vaccinations auditorium_5.fsm
Replies (9)
Message 2 of 10
jason_lightfootVL7B4
The easiest way is to add a zone to the process flow that is global across the instances and then pin the zone statistics to a dashboard. Model attached.
covid19-vaccinations-auditorium-5_jl.fsm
Message 3 of 10
tee_hiett
Nice try @jason.lightfoot.
Although a seat is released just before the Exit Zone activity, the label "Used" is not even check for reset until the custom code in the activity Clear Row. Even then the label will not be changed until the census on the role is equal to zero.
Note in the dashboard how the chart Seats with Used = 1 mirrors the chart census. Around the time of 7:21 AM the line should not gradually decrease but to stay constant until all of the 6 patients on the role have exited and then the line should decrease by 6.
Thanks for trying and I welcome any suggestions.
Tee
Message 4 of 10
Ah okay - like this:
I pushed and pulled from a list and plotted the content of the list. Jordan or Matt might have another method. I set the label on the token called Seats during your "Clear Row?" code activity.
covid19-vaccinations-auditorium-5_jl2.fsm
Message 5 of 10
tee_hiett
@jason.lightfoot I get this error message when I try to download your solutionImage.png
Message 6 of 10
joerg_vogel_HsH
@Tee Hiett and @jason.lightfoot both of your last comments are missing any content of attached pictures. 35618-ee653892-eb54-46ee-8ad3-9b3f36f831eb.jpeg
Message 7 of 10
tee_hiett
@jason.lightfoot and @Jörg Vogel I cannot down the solution
covid19-vaccinations-auditorium-5_jl2.fsm. I get the error message:
HTTP Status 403 - Forbidden
Apache Tomcat/7.0.107
Tee
Message 8 of 10
Message 9 of 10
tee_hiett
@jason.lightfoot I am unable to download your solution #2 in your response below this response.. I get the error message that the Server understood the request but refused to authorize it. HTTP Status 403
Message 10 of 10
tee_hiett
Thanks, @jason.lightfoot for the solution in your model:
and for clearing the problem with the website.
Your use of a list was right on time. I was trying, with no success, to use that approach. Your model not only solved my problem but will help learn about using Lists.
I will close this question and post additional questions that arise as I study the actives in your solution and learn more about using lists.
Tee
