N-Dimensional Tables
joe_s2
joe_s2
[ FlexSim 20.2.3 ]
Good Morning,
I've recently been working with tables and expanding tables to cover more cases and it got me wondering...
Is it possible to create N-dimensional tables in Flexsim? (example: table[row][column][dim3][...][dimN])
I'm currently working around this by using subnodes to account for higher dimensions but the code is getting a bit busy with Table(node.subnodes[dim3].subnodes[...],subnodes[dimN])[row][col].
JordanLJohnson
The Table class itself is designed to be a 2D table. If the depth is a multiple of two, you could maybe chain Table calls. The .cell() method gets a node, which you can then treat as a Table:
// Access deep nodes
// .value accesses the value on the final node
Table(node).cell(dim1, dim2).as(Table).cell(dim3, dim4).as(Table).cell(dim5, dim6).value
The [] syntax is also available on the Array class, and Arrays can contain other arrays. So the following code would work:
Array deepArray = [[[1, 2], [3, 4]], [[5, 6], [7, 8]]];
someNode.value = deepArray;
int value = someNode.value[2][2][1];
The downside of this approach is that it can be harder to investigate the structure; it's not as easy to investigate in the tree as a treenode structure. You can right-click a node with Array data, and choose Explore->As Table. but that view shows a list of entries.
If syntax is the main concern, and you want to have a shorter way of accessing a deep tree structure, you could add a user command, something like this:
// You can make a user command that takes a node and an array,
// and returns a value from the substructure
double someValue = getDeepData(node, [2, 1, 3, 1, 2]);
The code for that command would look like this:
/**Custom Code*/
treenode target = param(1);
Array keys = param(2);
for (int i = 1; i <= keys.length; i++) {
    // this could throw exceptions if the key requests a nonexistant subnode
    target = target.subnodes[keys];
return target.value;
See the attached example for an example of each of these approaches.
IndexExample.fsm
Jordan Johnson
Principal Software Engineer
