Multiprocessor Process Custom Task Sequence
ABarranco
ABarranco
[ FlexSim 23.1.3 ]
I want to set a specific work position for the operator when working on a multiprocessor.
Normally, when I need to do this with single processors I use a basic custom task sequence, but in this model I need to use multiprocessors.
I thought the logic would be similar, but when I use the same task sequence I have found that the operator keeps busy and is not being released when the process has finished.
I guess the pick operator logic is not the same on the processor and on the multiprocessor but I haven't been able to find any information in the manual
In the attached model you can find a processor with the custom task sequence that is working, a multiprocessor with the same logic that is not working and a second multiprocessor that is using the default custom task sequence that appears to be incorrect.
Multiprocessor_CustomTask.fsm
Best regards!
jonah_kendellR47TC
The multiprocessor does use different parameters than the processor so that exact code won't work. Instead, I was able to make the same functionality using the Custom Task Sequence Example 1 for the multiprocessor. Instead of the custom tasks being TASKTYPE_LOAD, TASKTYPE_BREAK, etc., I instead use the same tasks you had in the processor:
stopobject(current, STATE_WAITING_FOR_OPERATOR);
taskSequence.addTask(TASKTYPE_TRAVEL, current.WorkPosition, NULL);
taskSequence.addTask(TASKTYPE_STOPREQUESTFINISH, current, NULL);
taskSequence.addTask(TASKTYPE_UTILIZE, item, current);
Since this code returns 0 and won't be called again, we will "manually" release the operator with an On Process Finish trigger on the multiprocessor:
freeoperators(current.centerObjects[1], item);
This should give you the same behavior you were getting with the processor custom task.
multiprocessor-customtask_JK.fsm
