Multi-load with Assigning type
mawyun
mawyun
[ FlexSim 21.0.10 ]
I encountered some problem when conducting multi-load with the assigning type. I register my data in "GlobalTable1". This is the step I used:
1. Convert the input data in global list to an array with FlexScript. (from "type_transform" to "type" )
2. Register the number of goods that needs to be load in "load_count"
3. Use subflow to try to load the right type of data
But I am not sure how to get the position of array in global table correctly to achieve multi-load with the assigning type of data. Thank you for any of your kind suggestions and help!
Model:0427-multi-load.fsm
moehlmann_fe
The settings of the "Run Sub Flow" activity should look something like this.
- Create as many tokens as there are entries in the "type" array
- Assign each child token one of the type values
Jeanette_Fullmer
Hi @chia725, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
