MTBC-MTTR DEFAULTZERO
ALDOGKZ
ALDOGKZ
[ FlexSim 20.1.3 ]
I'm having troubles with the MTBF function, and specifically with the one in my model designed for the off time called "Lunch", at the 11:30 a.m. the line stops and around 12:00 the start gives me the next issues:
time: 18368.809456 exception: Invalid AGV Body Offset. The defined body offset leads to a negative travel distance.
time: 18368.809456 exception: Exception Caught in FlexSimObject::resume(int id, int stateprofile DEFAULTZERO) object: /AGV RH 7
time: 18368.809456 exception: Exception Caught in resumeobject(treenode involved, int id)
time: 18368.809456 exception: Exception Caught in ObjectFunction200__project_exec_commandlist_resumeobject_node object: MAIN:/project/exec/commandlist/resumeobject/node i: MAIN:/project/exec/commandlist/resumeobject/node class: MAIN:/project/exec/commandlist/resumeobject/node
time: 18368.809456 exception: Exception caught in TreeNode::callMemberFunction() c++/dll execution. Throwing... MAIN:/project/exec/commandlist/resumeobject/node c: MAIN:/project/exec/commandlist/resumeobject/node i: MAIN:/project/exec/commandlist/resumeobject/node thisClass: MAIN:/project/exec/commandlist/resumeobject/node
time: 18368.809456 exception: Exception caught in evaluation of MAIN:/project/exec/commandlist/resumeobject/node
time: 18368.809456 exception: Exception Caught in FlexSimObject::resume(int id, int stateprofile DEFAULTZERO) object: /AGV LH 11
What's the main issue that is causing this problem? I see that the line stop around 2 hours and the continues until the stop time...
julio_r
Hello @Aldo G11 ,
Could you send the model so we can review the problem?
ALDOGKZ
I was trying to upload it but there's something wrong with the page 😞
julio_r
Please send it to my email: juliorosell@flexsim.com.mx
Jeanette_Fullmer
Hello @Julio R and @Aldo G11,
Was a solution able to be reached? Can this post be closed?
