Mount robot on top of task executor
simulaciones_dctc
simulaciones_dctc
[ FlexSim 18.0.6 ]
I want to know how i could mount a robot on top of a task executor. The robot only needs to move when the task executor reaches a workstation. any ideas on how i could achieve this?
tanner_p
This can be done by dragging out a task executor from the library, then dragging a robot on top of it and referencing them separately in your process flow. I've attached a sample model to demonstrate how this works.
robot-task-executer.fsm
simulaciones_dctc
this is exactly what i needed!!!! thank you!!!
Shaheera-Bedir
Could you please help me understanding this msg
its appear when i did the same simulation you did
joerg_vogel_HsH
@Shaheera-Bedir , a robot can act like a vehicle alone. You need to bind it to a network node path system and let it transport items. After such a first initialization this robot behaves like a vehicle even, if it is not connected to a network node path system anymore.
Attached an example of FlexSim 16. let_robot_move_like_vehicle.fsm
Please add more information to your request and it is best suited to ask a new question.
