modifying code in VIEWS:/rootmenu and VIEWS:/standardviews cannot be persistent
poeychingneo
Observer Observer
Message 1 of 10
poeychingneo
Observer
Observer
[ FlexSim 18.1.1 ]
I am attempting to do 2 things which I though can be achieve by modifying code in VIEW:/ nodes. However, my code changes "disappear" after I saved my model. Some details are given below. Am I approaching it the wrong way?
a) to disable model tree view
- attempt to change in VIEW:/rootmenu subnodes
b) to disable the Quick properties view for dashboard.
- attempt to change in VIEW:/standviews/modellingutilities/QuickProperties eventfunction node.
Replies (9)
Message 2 of 10
SCHamoen
@pc neo This is correct, those changes are not saved in your model. If you want to do this you have to create a module and take a look at the Environments option. This post also deals with this.
Message 3 of 10
poeychingneo
Observer
Observer
I am not able to access "post" link. I get a "access denied".
Message 4 of 10
poeychingneo
Observer
Observer
@steven.hamoen
Message 5 of 10
joerg_vogel_HsH
I haven't got access neither.
Message 6 of 10
joerg_vogel_HsH
If it doesn't bother you, maybe you save the changed workspace view as default. I am not certain, if this solves a part of your question.
Message 7 of 10
SCHamoen
@pc neo @Jörg Vogel I have the same problem when I'm logged in but not when I log out and then click the link. So if you want to see it you have to log out first. @Ben Wilson can you check what is going on here?
Message 8 of 10
Ben_WilsonADSK
That question was not in the simulation questions space. I have moved it there and it should now be publicly accessible.
@Jörg Vogel, @steven.hamoen, @pc neo
Message 9 of 10
poeychingneo
Observer
Observer
Message 10 of 10
poeychingneo
Observer
Observer
thank you. It helps to a certain extent.
