Modify the maximum of the Run Speed
omar_aguilera_rico
omar_aguilera_rico
[ FlexSim 19.1.1 ]
Hi!
It is possible to modify the maximum of the RUN SPEED so that when it is 64 it is the maximum, and it should not be 100000000 the Maximum number. I opened the code and on line three I change to 64 so when the RUN SPEED reaches that value I want it to be the Maximum but it doesn't work. This is possible? If possible how do I modify it?
Thank you!
philboboADSK
If you want to modify the View tree, you need to use the Module SDK.
Phil BoBo
Sr. Manager, Software Development
Matthew_Gillespie
Are you trying to do this for just a single model? If so you could use a model environment.
Matthew Gillespie
FlexSim Software Developer
omar_aguilera_rico
Only I want to do a single model.
philboboADSK
The documentation for creating environments, including model environments, is in the Module SDK.
Phil BoBo
omar_aguilera_rico
Thanks @phil.bobo!
