Modification of global table by using model reset trigger
kjunwoo
kjunwoo
[ FlexSim 18.1.2 ]
Hi all, I have a problem with model reset trigger.
I want to insert a number of rows into a global table when model is reset,
and my scripts for this purpose is as follows:
Table wip_table = reftable("WIP");
wip_table.addRow(1);
No error message is shown when model is reset, however, it seems that this script doesn't work. (new row was not added)
Also, I fail to add new row when I modify the second line of script as follows:
wip_table.setSize(1, n); // n is number of columns
On the contrary, the above script works well when I put it into Script Window or triggers of modeling object.
Could you please help me to modify the global table by using model reset trigger?
allister_wilson
I reproduced what you described in version 18.1.2, it seems to work as expected.
See if the attached model works on your end.
joerg_vogel_HsH
You can try this on an Object reset trigger or on the OnModelReset trigger
Table("WIP").addRow(1,DATATYPE_NUMBER); // add a row before row 1
int rows = Table("WIP").numRows;// get the rows of the table
Table("WIP").setSize(rows,7,DATATYPE_NUMBER,0);// set the column count to 7
kjunwoo
Thank you, Allister and Jörg.
I found that the problem was occurred by the On Reset trigger of the global table, which deletes all rows.
When I delete the trigger of global table, the script for adding row works well.
Thank you again.
