[ FlexSim 20.0.0 ]
sample-rack-1.fsmAttached is a model with Rack setup in the old way, that is objects are connected to the Rack using 'A' connection. It is observed if model is run at max run speed, it will stop after sometime with some flowitems still in the rack not send out of rack even after dwell time is up.
I've tried 2 settings and both sees the same issue:
a) The rack is setup to have a max content of some small number like 30 with slot assignment of matching labels (without hasSpace).
b) The rack is setup to have slot assignment of matching labels (with hasSpace).
