Model with AGV stops at 36.20 minutes without any error message
rohith_v2
rohith_v2
[ FlexSim 21.0.1 ]
36409-agv-training-question.jpgI'm trying to execute a simple AGV simulation following a training video and every time I try to run the model it stops running at 36.20 minutes. I'm not seeing any error message as well. I would like to know if there is something wrong with the model or I have to missed to define any parameters.
jason_lightfootVL7B4
If you post the model we can take a look.
joerg_vogel_HsH
You have set the source to create an item by schedule arrival. The item is created, the agv transports the item into the sink. The item enters the sink at 36.20 minutes. There aren’t any more items to transport. The model stops. If you saw more items transported, you set the source to create for example 5 items at time 0 and 5 items entered the source. The last item entered at 36.20. Please change the creation mode to interarrival time and set a time of arrival to 50.
rohith_v2
@Jörg Vogel The source model has been set up at the interarrival time itself. I do not see any item generated at source or getting moved to the sink. I have attached the model, can you please take a look and let me know what needs to be changed. Thank you!
Training model_AGV.zip
joerg_vogel_HsH
Taskexecuters are connected from the dispatcher to themself by an Object connection A-Type. Not a center connection.
rohith_v2
Works Now. Thank you!
