Mixed models in one production line
huy_n2
huy_n2
[ FlexSim 22.1.0 ]
If having 2 models (X &Y) is produced by 1 assembly production line with ( 5 station A , B, C,D ,E) and model Y is no need to assemble by station D so how do I do the setting ?
Noted: cycle time of 2 models for each station is different
moehlmann_fe
Observer
Observer
Give each item a label that shows their type and create a second connection from processor C that leads directly to processor E.
In processor C's 'Send to Port' option, set it to send the item to the correct connection depending on its type.
PortByCase.fsm
jason_lightfootVL7B4
If there's no flexible routing as @Felix Möhlmann is using - and each model visits all the stations then you just need to read the operation time for that station from data and for model Y doing OPxx at StationD that lookup should return a zero process time (due to not having a viable operation to perform at D).
kavika_faleumu
Hi @Huy N2, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
