Mirrored objects with custom shape becomes dark
guldbergdk
guldbergdk
[ FlexSim 24.0.0 ]
Found this odd issue when trying to create a mirrored copy of a basicFR with a custom loaded .dea shape. If I mirror it in Flexsim by copying the original and setting the dimension to minus in the Y direction it becomes dark. The same thing happens if it mirror the shape in blender and create a new object and import it.
Any workarounds?Pallet work station.fsm
jason_lightfootVL7B4
It looks like the normals are pointing inward, so either use a menu option in an external tool to do the mirror, or recalculate the normals.
The last version where a negative dimension would not cause a dark image was v7.1.
Hi @Guldberg, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
