Maximum Occupancy Based On Simulation Time
abeer
abeer
[ FlexSim HC 5.1.0 ]
Hi all,
I want the maximum occupancy to change based on simulation time, I wanted to have a global table where it reads the different occupancy values at different times but seems the maximum occupancy field takes only numerical values!
Matthew_Gillespie
You can put individual objects on a shift schedule and make them go off schedule at certain times. You could also use the Based on Simulation Time pickoption to only send patients to certain areas during a specified time interval. You could also try using a user event to set the maximum occupancy variable on the object.
Matthew Gillespie
FlexSim Software Developer
