Match value
Match value
zhun_z
Match value
zhun_z
[ FlexSim 21.2.4 ]
Match Value.fsmExcuse me, when i use the "match value" as the monitor condition, i can't get the right running result. Please help me to find the problem, thx!监听.gif
kuooge009
sorry.i dont kn what you said is that the running result is incorrect. Aren't all processors pushed to the list?
moehlmann_fe
"match value" compares the event parameter to a static value that is determined on model reset. It is not dynamically evaluated each time the event happens. I think what happens in your is that the value is evaluated for each instance in order and thus only the value of the last instance "sticks".
To create tokens in the correct instance I would suggest to simply always create a token and sort out the wrong ones in a subsequent decide activity.
match_value_fm.fsm
zhun_z
Thanks, I have not known that the activity "match value " will be triggered on model reset, thank you for your explanation.
