Mass flow Transfers Btwn Two Mass FlowConveyors Doesn't Scale As Per Model Units
arunTTT2P
arunTTT2P
[ FlexSim 23.2.1 ]
When connecting two mass flow conveyors in a model made in inches by "A" connection the size of the mass flow transfers is too small. Their size is not adjusting as per the model units. For normal conveyors it works fine.massflowissue.fsm
kavika_faleumu
Hey @Arun Kr, this is a bug. I will add this to the dev list.
In the meantime, you can work around this by adding a Properties Table to your model, taking the size of a regular transfer, and resizing the disproportional one.
(Notice the difference in sizes. Copy the size from the regular EntryTransfer1 and copy over the size of the MassFlowTransfer1 and 2)
Matthew_Gillespie
@Arun Kr This issue is now fixed in 23.2.2
Matthew Gillespie
FlexSim Software Developer
