Making object [ConveyorSystem] with Flexscript
wooram_kim
wooram_kim
I want to make a ConveyorSystem without dragging a conveyor object into the model.
Therefore, I used the following script and it seems to work well. Is it a proper way?
  • Object conv_system = createcopy(maintree().find("project/library/conveyor/ConveyorSystem"), model);
    conv_system.name = "ConveyorSystem";
But the following script does not work, even though the manual recommends using treenode.copy() instead of createcopy(). What is the difference?
  • Object conv_system = maintree().find("project/library/conveyor/ConveyorSystem").copy(model);
Thank you.
FelixMoehlmann
The 'proper' way would be to use the "create()" method of the Object class.
https://docs.flexsim.com/en/25.1/Reference/CodingInFlexSim/FlexScriptAPIReference/Tree/Object.html#M...
Object.create("Conveyor::ConveyorSystem")
I don't know why copy() doesn't work and what differences there are between the commands though.
